Docker with Tailscale & Jellyfin assistance
I recently setup a Ugreen NAS and setup my RAID mirroring etc. I am able to access it from my Mac for setup, which works great. I’m having an issue, though. I tried and tried to wade thru Reddit posts, blogs & even tried openAI (lort help me as I reinstalled Tailscale a billion times when doing this) - and it didn’t resolve the issue.
Previously had Tailscale & Jellyfin running on my Mac and accessing from my phone via FinAmp / Tailscale address (as my phone is also running Tailscale) and it was working flawlessly.
Fast forward to yesterday where I created a Docker project named mediaserver - which installed the containers for tailscale & jellyfin. While I do have quite a bit of previous network and pc experience (I work in the technological field) - this is my first journey into the NAS / Docker environments. See code below - what am I missing??
Current Issue: Finamp on phone will not connect to this new setup on the Ugreen NAS. Trying to connect with http://nastailscaleip:8096 (as that’s what I did with the previous ip) and it gives errors.
  1. I can access my Jellyfin from my Mac via the local address and am unsure what to try next.
  2. My firewall is OFF on my NAS, if that makes a difference.
  3. I tried all kinds of things in the networking on the jellyfin side of things, still not working.
Project compose configuration (that ai assisted with):
  tailscale:
image: tailscale/tailscale:latest
container_name: tailscale
restart: always
network_mode: host
privileged: true
      - /dev/net/tun:/dev/net/tun
      - TS_AUTHKEY=tskey-auth-MYKEYISHERE
jellyfin:
image: jellyfin/jellyfin:latest
container_name: jellyfin
user: "0:0"
restart: always
network_mode: host
      - /volume1/docker/jellyfin/config:/config
      - /volume1/docker/jellyfin/cache:/cache
      - /volume1/media:/media
Hi. I have this working. My Docker compose file is below in case it helps.
networks:
frontend:
external: true
tailscale-j:
container_name: tailscale-j
  - TS_AUTHKEY=xxx
  - TS_STATE_DIR=/state
  - ./config:/config
  - ./state:/state
cap_add:
  - net_admin
  - sys_module
restart: unless-stopped
networks:
  - frontend
ports:
  - 8096:8096
jellyfin-tailscale:
container_name: jellyfin-tailscale
network_mode: service:tailscale-j
depends_on:
 - tailscale-j
restart: on-failure:3
devices:
 - /dev/dri:/dev/dri  # Integrated graphics
PUID: 0
PGID: 0
 - ./config:/config
 - ./cache:/cache
 - type: bind
source: /volume1/Video
target: /media
 - type: bind
source: /volume1/Music
target: /media2
 - type: bind
source: /volume2/Vol2 Video
target: /media3
 - type: bind
source: /volume2/iMac Photos
target: /imacphotos
 - type: bind
source: /volume1/Photos
target: /photos
read_only: true
Thanks for the response, @pemmo. I must be doing something very wrong because I tried to make some edits to change some lines on my composer to match what you have and it’s giving me all kinds of errors.
Even when I put my original composer line back in it gives me errors - though it ran before - and now my Tailscale keeps restarting.
Unsure what to do. I’ll report back if I figure it out, or if anyone else has any guidance it’s much appreciated.
Ok so after a lot of troubleshooting I tried again following these two tutorials to a t.
docker / tailscale: https://www.youtube.com/watch?v=cfM3OwEXZao&t=528s
docker / jellyfin: https://www.youtube.com/watch?v=P9-26gd9ons&t=143s
Then after doing that it kept giving me an invalid password error; turns out I mistyped my password when first configuring jellyfin. Reset it with their reset tool and VOILA! I can now access my jellyfin music library through finamp on my phone.
:clap:
One more thing - since I am so green to Linux.. I didn’t know it paid attention to the case of words in file names.
For instance - I had a file named General that I renamed general. Windows & Mac would still find it just fine.. but Linux.. NOPE! Had to update it to general everywhere else.
Lots of learning going on here. Yay!
