DXP4800plus 10GBPS ethernet problems :(
I have just purchased a USB4 to 10GbE Network Adapter for my minisforum um780 xtx mini pc because i have no pci slots, but I’m having a lot of trouble getting this to work :(.
I have connected the adapter to my USB4 (USB-C) then connected a network cable from that to my 10Gbps port on my Nas but i am still getting really low transfer speeds from my pc to my nas storage.
I have put a link to the adapter i have bought below.
Any help would be really appreciated.
https://www.amazon.co.uk/dp/B0FZFQD5KT?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Care to share some actual useful information, like how you’ve configured things, what kind of speeds you’re getting, how you’re testing etc.?
It’s really impossible to give you any kind of help based on the information provided.
It is highly probable that the connection issues you’re experiencing are related to the USB-Ethernet dongle rather than the NAS hardware itself.
For info - I have a DXP4800GT and there does seem to be an issue with the NICs.
The NAS is connected to a Unifi USW Flex XG and will auto-negotiate to 5Gbps, hard code to 10Gbps and the link drops.
I can configure a LACP LAG group with both NAS NICs to get a LAG group of 10Gbps but single flows will be restricted to 5Gbps.
I’ve got a case open with UGREEN. To rule out the 10G switch (I’ve tried different firmware, physical switches and high end ethernet cables - all new) I may order a Unifi 10G Ethernet Adapter ( 10G Ethernet Adapter - Ubiquiti Store ) and try from a TB5 port on my Macbook.
If I get to the bottom of this, I’ll happily share the info. For now I just have a ton of data from both the Unifi and NAS (ugos is Debian 12 (I think) based, so using scripts and cli commands to troubleshoot).
After substantial troubleshooting, with a variety of 10G connected devices, I’ve had to RMA the NAS.
As engineering have not provided any root cause, I’m currently not planning to buy a replacement which is quite dissapointing.
Not seeing the issues you had with the DXP4800GT, got a basic, unmanaged 10 Gbps switch.
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-10.01  sec  11.6 GBytes  9.91 Gbits/sec                  sender
[  5]   0.00-10.01  sec  11.6 GBytes  9.91 Gbits/sec                  receiver
