Firmware 1.13.1.0105 is out
It appears as if Ugreen has shifted to a beginning of the month release schedule now.
There doesn’t appear to be any major updates for most of us. One thing I noticed though is that the image file is about half the size compared to the previous three releases.
【Control Panel】
  1. Hardware & Power > UPS: Adjusted the minimum custom time to 1 minute in both standby mode and auto shutdown mode.
  2. Fixed an issue where the AX1800 wireless network card did not automatically enable after system reboot.
【Storage】
  1. Hard Drive > Status test plan: Updated IHM detection tool version to optimize the detection mechanism for Seagate IronWolf hard drives.
  2. Optimized read & write performance in RAID10 mode.
【Files】
  1. Network Folder now supports mounting “Quark Drive”.
  2. Web/PC: Supports creating new folders or documents by right-clicking in blank areas.
  3. Mounted cloud drive paths can be used as target paths for compression or decompression.
  4. Supports viewing details of photos in mounted cloud drives.
  5. Optimized download speeds for 115 Life members under high-bandwidth conditions when using mounted drives.
  6. Fixed abnormal playback of M4B audio files.
【Others】
  1. Optmized the configuration of hosts files.
  2. Optimized time synchronization mechanism and fixed two-factor authentication failure caused by time abnormalities.
  3. Fixed an issue where photos taken with the front camera of Apple devices appeared upside down in thumbnails after upload.
  4. Fixed some known issues to improve user experience.
