Internet Connection Monitor
Hey all,
Have the DXP4800PLUS and loving it. Got VMs for doing my LiveDrive backups and torrents. Anyone know of a decent way to get it to monitor my Internet conection stability? Not interested in speed, just if it drops out and logs it. Maybe a docker as i have a few set up already for Plex Server & WiFi backhaul performance
Regards
Bobby
Hello, I would go with Uptime Kuma ( https://hub.docker.com/r/elestio/uptime-kuma) . Easy to run and many notification options .
You probably know this already but - if your Ugreen is monitoring its own internet connection, it won’t be able to send notificatoin when the connection is down, because it has no connection.
So ideally Kuma on Ugreen should be monitoring another network not its own.
Hi, I’ve downloaded and installed. Exactly what i need. thx so much :slight_smile:
