Ok so.. how do I activate the Recycle Bin for all shared and personal folders? It’s gotta be simple.. right?
Unfortunately it seems like you can only enable the recycle bin when you create a new folder… Seems like something of an oversight by Ugreen and far from the only one.
I suggest you head over to the official forum and file a feature request with the support team.
https://community.ugreen.com/nas/#/nas/Support/index
Edit: It seems like I was mistaken, it just wasn’t very obvious how to do it. You need to click on the bin symbol in Files, then on the cog-ish looking thing for settings and go to Recycle bin management and there you can enable the recycle bin for various folders…
That was not logical at all.
