Scheduled shutdown not working
I have a scheduled shutdown task - Everyday-22:00 (Control Panel > Hardware & Power > Power) that only works randomly. Anyone else with this issue? I also have a Boot task that works as expected.
Maybe try the official forum or Ugreen support, this is an unofficial forum.
https://community.ugreen.com/nas/#/
OK, thanks for the advise - done.
Me too.
I’m using a scripted ssh to shut it down if it running 30 mins after scheduled shutdown
That script is on my list - any chance of sharing it?
I’m embarrassed that is just one line.
bigcat@pihole02:~ $ cat halt-ug.sh
#!/bin/bash
ssh -o BatchMode=yes -o StrictHostKeyChecking=no ugadmin@192.168.10.7 “lsblk /dev/sda”
bigcat@pihole02:~ $ ./halt-ug.sh
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 14.6T 0 disk
├─sda1 8:1 0 15.3G 0 part
└─sda2 8:2 0 14.5T 0 part
└─md1 9:1 0 29.1T 0 raid5
└─ug_75C7F5_1756408054_pool1-volume1 253:0 0 29.1T 0 lvm /home
/volume1
replace lsblk /dev/sda with say “sudo halt”
I schedule the script from the local system using cron
(crontab -l 2>/dev/null; echo ‘0 2 * * * //home/dave/halt-ug.sh’) | crontab -
I’d probably put some logging - date of invocation, test that it worked
Later I might wakeonlan to wake up the NAS at 06:45
/usr/bin/wakeonlan 6C:12:34:56:78:FF # Ugreen NAS01
something like
#!/bin/bash
CRON_TMP=$(mktemp)
Keep existing crontab (if any), remove old wakeonlan entries to avoid duplicates
crontab -l 2>/dev/null | grep -v ‘wakeonlan’ > “$CRON_TMP”
Add new entries
cat <> “$CRON_TMP”
45 6 * * * /usr/bin/wakeonlan 6C:12:34:56:78:FF # Ugreen NAS01
46 6 * * * /usr/bin/wakeonlan 7C:12:34:56:78:FF # Ugreen NAS02
EOF
Install new crontab
crontab “$CRON_TMP”
Clean up
rm “$CRON_TMP”
